[其他] SAP CRM Transaction codes
Twilight发表于 2016-01-28 00:48Twilight 最后回复于 2016-01-28 00:48 [复制链接] 6091 0
  1. SE19 BADI Implementation
  2. SE93 Transaction code check
  3. SMW01 Workflow
  4. Crm_Erms_mailForms Forms
  5. SWDD ERMS Rule modler workflow
  6. SE18 BADI creation
  7. SE11 Tables
  8. SE38 Functional module reports/fields display
  9. SE16 TSTC
  10. SE93 Application Component - get there displayed all transaction codes for example crm-md-bp
  11. CRMD_ORDER Creating marketing sales and service transactions
  12. CRM_MKTPL FOR search campaigns deals
  13. SOST TransmissionRequest forms
  14. SCOT Administration system status
  15. CRM_UI_FRAME Access BSP WD work bench
  16. BP Business Partner (Creation/View/Modification)
  17. CIC0 Customer Interaction Centre
  18. CRMD_ORDER - CRM Transaction (Create/View/Modify)
  19. SPRO Configuration related settings
  20. CRMD_CALL_LIST Create/ Maintain Call list
  21. IB51 / IB52 / IB53 Ibase Creation / Change / View
  22. COMMPR01 Maintain Products
  23. PPOSA_CRM Display Organizational Model
  24. SBDM Bdoc maintenance
  25. SMOEAC Administration console – CRM Middleware
  26. SMQ1,SMQ2 Queue monitoring transactions for inbound and outbound queues.
  27. SMW01 Transaction for monitoring bdocs.
MIddleware T-Code
  1. SM66Work process overview
  2. ST06 CPU and memory consumption
  3. ST02 SAP memory and buffers
  4. ST04 Database performance counters
  5. SM04 Memory consumption per user
  6. ST10 Table call statistics
  7. OS07 CPU & Memory Consumption on IPC Server
  8. SMQ2 CRM Inbound Queue
  9. SMQ CRM Outbound Queue
  10. R3AM1 Monitor Load
  11. R3AR2 Define Request
  12. R3AR4 Run Request
  13. CRMM_BUPA_MAP Request Business Partner
  14. CRMM_BUPA_SEND Send Business Partner
  15. ST03 RFC statistics (client and server)
  16. SM58 Errors in transactional RFCs
  17. SMWM FLOW BDOC Statistics
  18. ST03 & STAD Response time statistics
  19. SMWP Error Tracking
  20. SMQS Q-Out Scheduler
  21. SMQR Q-In Scheduler
  22. SMW01 & SMW02 Bdoc Error Tracking
  23. ST22 Short Dumps
  24. SMOEAC Admin Console
  25. SM50 Process Overview
  26. AL08 User List
  1. SDIMA Data Integrity Manager
  2. CRMBS02 Maintain Status Profiles
  3. CRMBS03 Display Status Profiles
  4. CRMBS42 Maintain Status Selection Profiles
  5. CRMBS43 Display Status Selection Profile
  6. CRMBS52 Maintain Authorization Keys
  7. CRMBS53 Display Authoriztaion Key
  8. CRMBWST Genertd DataSource for BW Status Obj
  9. CRMBWTARGETS Release Data Target for BW Upload
  10. CRMBW_CIC_ATTRIBUTES BW Key Figures for CRM
  11. CRMCACTARC Archiving Control CRM Activity
  12. CRMCPRMSG Configure Customer-Specific Messages
  13. CRMCUSTOM Monitoring Middleware System
  14. CRMC_ACTION_CONF Configure Action Profile
  15. CRMC_ACTION_DEF Define Action Profile
  16. CRMC_ACTION_JOB Action Monitor
  17. CRMC_ACTION_PRINT Configure action profile (old)
  18. CRMC_ACTION_WIZARD Action for Definition via Wizard
  19. CRMC_ACTIVITY_H Customizing Maintenance Activity
  20. CRMC_ACT_CATEGORY Cust. Maint. Activity: Category
  21. CRMC_ACT_OBJ Cust. Maintenance Activity: Goal
  22. CRMC_ACT_SURVEY Cust. Maint. Activity: Questionnaire
  23. CRMC_AM_JCLASS Alert Modeler Java Class
  24. CRMC_ATP_PROFILE Customizing Maintenance: APO Profile
  25. CRMC_BLUEPRINT Maintenance for BSP Blueprint
  26. CRMC_BLUEPRINT_C IMG Call
  27. CRMC_BL_CHECK Check Blueprint Tables
  28. CRMC_BL_COPY_QUERIES Copy Report Delivery Queries
  29. CRMC_BP_CCKPT_PB Cust.Maint. BP Cockpit: Pushbuttons
  30. CRMC_BSP_ANALYZE Starts CRMC_BSP_FRAME: Analysis Mode
  31. CRMC_BSP_WD_MSGDEFH Message Default Handler Assignment
  32. CRMC_BUAG_NUMBERS Number Range Maintenance: BUAG
  33. CRMC_BUPA_CONSUM Maintain reference business partner
  34. CRMC_BUPA_INITIAL Table Maintenance CRMC_BUT_INITIAL
  35. CRMC_BUS_SUBOB_C Assign. BUS - Allowed Appl. Areas
  36. CRMC_BUS_SUBOB_I Assignment BUS-allowed app.area item
  37. CRMC_BUT_CALL_FU Establishing FMs for Data Exchng BP
  38. CRMC_CAI_COCKPIT CAI - Test Cockpit
  39. CRMC_CATAGORY_WP Cust. Maintenance Application Area
  40. CRMC_CATALOG_DEFINE Create Catalog
  41. CRMC_CATALOG_OVV Catalog Overview
  42. CRMC_CIC_AB_LSYS_*** Action Box: Assign logical systems
  43. CRMC_CIC_AB_LSYS_CRE Action Box: Create logical systems
  44. CRMC_CIC_AB_LSYS_RFC Action Box: Assign LogSYS to RfcDest
  45. CRMC_CIC_AB_NAV Action Box Navigation Area
  46. CRMC_CIC_AB_WEBGUI Define ITS for WebGui Mode
  47. CRMC_CIC_ACT0 Transaction component profile
  48. CRMC_CIC_AM_LANG Lang. dependent text - Alert Modeler
  49. CRMC_CIC_AM_META Define Customer-Specific Meta Model
  50. CRMC_CIC_AM_PROFILE Maintan Alert Modeler Editor Profile
  51. CRMC_CIC_BP_PROFILE Maintain Profile Templates
  52. CRMC_CIC_BROAD broadcasting profile assign
  53. CRMC_CIC_COMP_ACTION Component Actions (for locator, BDD)
  54. CRMC_CIC_EXT_INB_ACT Activate Agent Inbox
  55. CRMC_CIC_FW_MAINTAIN Maintain Framework ID and Parameters
  56. CRMC_CIC_MAIL_ADDR Addresses for Agent Inbox
  57. CRMC_CIC_MAIL_E_RESP Maintain Rules for E-Mail
  58. CRMC_CIC_MAIL_F_RESP Maintain Rules for Fax
  59. CRMC_CIC_MAIL_GLOBAL Define Global Settings
  60. CRMC_CIC_MAIL_IBXPRF Define Inbox Settings
  61. CRMC_CIC_MAIL_TASKS Task Classification
  62. CRMC_CIC_MAIL_WF Assign Agent for E-Mail Handling
  63. CRMC_CIC_RESTART Set Time & Memory for Restart
  64. CRMC_CIC_SEARCH_CNTR Maintain Search Components
  65. CRMC_CIC_SEARCH_RULE Maintain Search Attributes
  66. CRMC_CIC_TITLE_TEXTS Maintain Window Title
  67. CRMC_CIC_WSP0 Workspace Definition
  68. CRMC_CIC_WSP1 Inbox Profiles
  69. CRMC_CIC_WSP2 E-Mail Editor Profiles
  70. CRMC_CIC_WSP3 Default Workspaces Profile
  71. CRMC_CIC_WSP_EDITOR2 Editor Profiles
  72. CRMC_CLM_ACTION_CONF Configure Action Profile
  73. CRMC_CLM_ACTION_DEF Define Action Profile
  74. CRMC_CLM_ACTION_WIZ Action for Definition via Wizard
  75. CRMC_CLM_BTSYNC Business transaction synchronization
  76. CRMC_CLM_CALLATTRS Call Attributes
  77. CRMC_CLM_CALLRESULTS Call results
  78. CRMC_CLM_CLDP Call list determination procedures
  79. CRMC_CLM_CLTYPES Call list types
  80. CRMC_CLM_CMPGPM Campaign priority mapping
  81. CRMC_CLM_CTMAP Calling Times Mapping
  82. CRMC_CLM_ORCC Order control components
  83. CRMC_CLM_RSCHVL Rescheduling validation procedures
  84. CRMC_CLM_SORCC Standard order control profiles
  85. CRMC_CLM_STMAP Call State Mapping
  86. CRMC_CPRICPROC Definition of Cust. Determ. Proced.
  87. CRMC_CP_BADI_F Copying BADI - Text Maintenance
  88. CRMC_CSDR_ADD_CUST Design Registration Project
  89. CRMC_CSDR_APPL_CUST Design Registration Project
  90. CRMC_CUST_APPLLAYOUT ViewCluster Mtnce CRMV_APPLLAYOUT
  91. CRMC_DPRICPROC Definition of Document Procedures
  92. CRMC_EXEC_BAB CRM: Start business applic. builder
  93. CRMC_EXEC_BAB_C CRM: Start OAS in customer mode
  94. CRMC_EXEC_BAB_D CRM: OAS in customer design mode
  95. CRMC_EXEC_BAB_S CRM: Start OAS in SAP mode
  96. CRMC_IC_ACPROF Maintain Activity Clipboard profiles
  97. CRMC_IC_ACTIONPROF Maintain Actions profiles
  98. CRMC_IC_ACTIONWZ Start Action Box Wizard
  99. CRMC_IC_ALERTMODELER Alert Modeler customizing
  100. CRMC_IC_AMWZ alert wizard
  101. CRMC_IC_AM_PHS Maintain Alert Modeler Placeholder
  102. CRMC_IC_AM_PRM Alert Modeler Input Parameters
  103. CRMC_IC_AUI_FWD Define Forwards for Inbox Items
  104. CRMC_IC_AUI_GEN Agent Univ. Inbox - CRMV_IC_AUI_GEN
  105. CRMC_IC_AUI_MAINCAT Define Main Categories
  106. CRMC_IC_AUI_MAP_PRI Map Native to Inbox Priorities
  107. CRMC_IC_AUI_MAP_STA Map Native to Inbox Status
  108. CRMC_IC_AUI_PARTNER Agents Universal Inbox - Partners
  109. CRMC_IC_AUI_PROFILE Define and Assign Inbox Profiles
  110. CRMC_IC_AUI_QUICKS Define Quick Searches
  111. CRMC_IC_AUI_TIMEPER Define Time Periods
  112. CRMC_IC_BDCCONTEXT Specify alternative BDC context
  113. CRMC_IC_BPPROF Define Profiles for Customer Identif
  114. CRMC_IC_BTPFAS Assignment of Partner Functions
  115. CRMC_IC_BTPROF Profile for Business Transaction
  116. CRMC_IC_CHTPROF Maintain profiles for Chat
  117. CRMC_IC_CLMPROF Call List Profile Maintenance
  118. CRMC_IC_CM Content Management Customizing
  119. CRMC_IC_EMLPROF Maintain profiles for Email
  120. CRMC_IC_EVENTING Event management customizing
  121. CRMC_IC_EVENTS IC WebClient Events
  122. CRMC_IC_MAIL_E_RESP Maintain Rules for E-Mail
  123. CRMC_IC_MAIL_F_RESP Maintain Rules for Fax
  124. CRMC_IC_MAIL_WF Assign Agent for E-Mail Handling
  125. CRMC_IC_MAIN Main Component Customizing
  126. CRMC_IC_MCM_CCPRO Define Com Mgmt Software Profiles
  127. CRMC_IC_MKTPROF Campaign Profile Maintenance
  128. CRMC_IC_NAVBARWZ CRMC_IC_NAVBARWZ
  129. CRMC_IC_NAVBAR_PERM Nav Bar Permanent Profile
  130. CRMC_IC_NAVBAR_PERS Nav Bar Personalizing Profile Defaul
  131. CRMC_IC_RTFRAMEWORK IC WebClient Runtime Framework
  132. Maintain Interactive Scripting Prof
  133. CRMC_IC_SPH_AGENTPRO Maintain Profiles for SPH Agent
  134. CRMC_IC_TLBPROF Maintain profiles for Toolbar
  135. CRMC_IC_TRACE Activate activity tracing for agent
  136. CRMC_IC_WCTPROF Maintain profiles for Web Context
  137. CRMC_IC_XML_TEMPLATE XML template maintenance
  138. CRMC_IIA_KERNEL IIA: Customizing for Learning Engine
  139. CRMC_IIA_REPORT IIA: Customizing for Learning Engine
  140. CRMC_IOBJ_FIN_STATE Change Status of Individual Objects
  141. CRMC_IPMO_BWSELOPT BW Select Optns: IPMO Sett.DataColl.
  142. CRMC_IPMO_SRVUSE IPMO: Usage from Feature
  143. CRMC_IPM_CLRRUL Clearing Control - Diagram Form
  144. CRMC_ISA_IUSER Internet User Settings
  145. CRMC_ITEM_CAT_GR Item Category Usage
  146. CRMC_ITEM_MA Customizing Maintenance: Item Cats
  147. CRMC_IT_ASSIGN Customizing Maint.: Item Cat. Dtrmtn
  148. CRMC_IT_COPY_IF Copy: Item category determination
  149. CRMC_IT_COPY_MA Copy Item Categories
  150. CRMC_IT_TYPE_US Item Category Usage
  151. CRMC_LAYOUTC_GENE Generation of Customer Table Layout
  152. CRMC_LAYOUT_GENERATE Generation of Layout Table
  153. CRMC_LOGS Maintenance of message classes
  154. CRMC_MAP Customer Maintenance Mapping
  155. CRMC_MKTCA_WF_CUST Workflows Campaign Automation
  156. CRMC_MKTLIST_WF_CUST Workflows External List Management
  157. CRMC_MKTPL_ACT_CONF Configure Action Profile
  158. CRMC_MKTPL_ACT_DEF Define Action Profile
  159. CRMC_MKTPL_ACT_WIZ Action for Definition via Wizard
  160. CRMC_MKTPL_FAW_CPG Field Selection Campaign
  161. CRMC_MKTPL_FAW_CPT Field Selection Campaign Element
  162. CRMC_MKTPL_FAW_DLM Field Selection Deal
  163. CRMC_MKTPL_FAW_MPL Field Selection Marketing Plan
  164. CRMC_MKTPL_FAW_MPT Field Select. Marketing Plan Element
  165. CRMC_MKTPL_FAW_TPM Field Selection Trade Promotion
  166. CRMC_MKTPL_FAW_TPT Field Selection Trade Element
  167. CRMC_MKTPL_MAPPING Customizing Field Assignment MS Proj
  168. CRMC_MKTPL_RT_AC Maintaning residency time
  169. CRMC_MKTPL_SETTYPE Marketing Planning: Process Set Type
  170. CRMC_MKTTG_CUSTMSG Configure Customer-Specific Messages
  171. CRMC_MKTTG_DTY CRM Marketing: View Display Type
  172. CRMC_MKTTG_MGR_H CRM Marketing: Report Name
  173. CRMC_MKTTG_OPT_H CRM Marketing: Sample Optimization
  174. CRMC_MKTTG_RUL CRM MKT: Split/Reduce Rules for TGs
  175. CRMC_MKTTG_SA_DP Assign Attribute Type to Display
  176. CRMC_MKTTG_SA_TP CRM Marketing: View Attribute Types
  177. CRMC_MKTTG_TYP_H CRM Marketing: Target Group Type...
  178. CRMC_MKT_PARAMBW Customizing for BW Parameter ID
  179. CRMC_MSGC Customizing CRM message attribute
  180. CRMC_MSGS CRM message attribute maintenance
  181. CRMC_NR_CONF Number Range Maint.: CRM_CONF
  182. CRMC_NR_MPK_MPOINT Number Range Maint.: Counter
  183. CRMC_NR_MPK_READING Number Range Maint.: Counter Reading
  184. CRMC_NR_RA_ACTIVITY Number Range Maintenance: CRM_ACTIVI
  185. CRMC_NR_RA_CONFIRM Number Range Maintenance:CRM_confirm
  186. CRMC_NR_RA_FANF Number Range Maintenance: CRM_SERVIC
  187. CRMC_NR_RA_LEADS Number range maintenance: CRM_LEAD
  188. CRMC_NR_RA_OPPORT Number Range Maintenance: CRM_OPPORT
  189. CRMC_NR_RA_SALES Number Range Maintenance: CRM_SALES
  190. CRMC_NR_RA_SERVICE Number Range Maintenance: CRM_SERVIC
  191. CRMC_NR_RA_SRV_CONF Number range maintenance: CRM_SRV_CF
  192. CRMC_NR_RA_SUR Number range maintenance: CRM_SUR
  193. CRMC_NR_SRV_CONF
  194. CRMC_OBJECTS Subobjects of CRM Document
  195. CRMC_OBJECT_ASSI Assignment Appl. Area - CRM Object
  196. CRMC_OPPORT_H Customizing Maintenance: Opportunity
  197. CRMC_ORGPROF Maintenance of Org. Data Profile
  198. CRMC_PARTNER_AS Maintenance of Access Sequences
  199. CRMC_PARTNER_FCT Maintenance of Partner Functions
  200. CRMC_PARTNER_MAP2CRM Mapping Partner Functions into CRM
  201. CRMC_PARTNER_MAP2R3 Mapping Partner Functions into R/3
  202. CRMC_PARTNER_PDP Maintenance of Partner Procedures
  203. CRMC_PARTNER_PFT Maintenance of Partner Function Typ
  204. CRMC_PFTREL BP PartnerFunctionCat.for Rel. Cat.
  205. CRMC_PLSRV_REL Product Proposal
  206. CRMC_PPR_CTRL Maintain Global PPR Settings
  207. CRMC_PPR_DEFINE_APPL Define Applications using PPRs
  208. CRMC_PPR_DEFINE_OCHK Transaction Types Rel. for PPR Check
  209. CRMC_PPR_DEFINE_PARA Customer Maintenance Rule Parameter
  210. CRMC_PPR_DEFINE_RULE Customer Maintenance Rule Definition
  211. CRMC_PPR_DEFINE_SRTB Define Sort Routines for BPartners
  212. CRMC_PPR_DEFINE_SRTP Define Sort Routines for Products
  213. CRMC_PPR_DEFINE_TYPE Customer Maintenance PPR Types
  214. CRMC_PRCPROC_DET Cust. Maint. Pr. type determination
  215. CRMC_PRCTYPE_DET Cust. Maint. Pric. Proced. Maint.
  216. CRMC_PROCESS_MA Customizing Maint.:Transaction Types
  217. CRMC_PROD_FIN_COPY Copy Financing Product
  218. CRMC_PROD_FIN_HIER Create Financing Hierarchy
  219. CRMC_PRPS BP Function Proposal Procedure
  220. CRMC_PRP_IL_MAP PPR-Customizing: Maintenance Mapping
  221. CRMC_PRP_OBJECTS PPR-Customizing: Maintenance Mapping
  222. CRMC_PR_COPY_MA Copy Tranasction Types
  223. CRMC_R3_ORG_GENERATE R/3 organizational data generation
  224. CRMC_SALES_ITEM Sales Customizing at Item Level
  225. CRMC_SERVICE_H Customizing Maintenance: Service
  226. CRMC_SERVICE_IPT Maintenance of Internet Trans. Types
  227. CRMC_SLS_ITM_BIL Maint. Item Types & Billing Relev.
  228. CRMC_SRVCATIFC Catalog Integration
  229. CRMC_SUBJPROFILE_H Define Subject Profile
  230. CRMC_SUBOB_CAT Application Areas
  231. CRMC_SUBOB_CAT_I Item - Business Object Types
  232. CRMC_SWITCH_ORGMODEL Convert Org. Model
  233. CRMC_TAX_CUST_UPD Maintain Condition Function in Cond.
  234. CRMC_TAX_GROUP Tax Group Customizing
  235. CRMC_TAX_MAP Tax Group Customizing
  236. CRMC_TAX_SCHEMA Maintain tax procedures
  237. CRMC_TIMEPROF CRM date profile
  238. CRMC_TM_CLPROF0 Call list profile maintenance
  239. CRMC_TM_NSM Namespace manager
  240. CRMC_TM_PSM Persistent storage manager
  241. CRMC_WEBREQ Request Categories for Web Requests
  242. CRMC_WEBREQ_BEGR Authorization Groups for Views
  243. CRMC_WEBREQ_BEGR_DIS Authorization Groups for Views
  244. CRMC_XMLEDITOR Start XML Editor for Spice
  245. CRMD_AR_MAINTAIN Process Product Association Rule
  246. CRMD_BILLING Transfer Invoice Data to R/3
  247. CRMD_BILL_REV Cancel Billing Document
  248. CRMD_BUS2000107 Process Framework Agreements
  249. CRMD_BUS2000108 Maintain Leads
  250. CRMD_BUS2000111 Maintain Opportunities
  251. CRMD_BUS2000112 Maintain Service Contracts
  252. CRMD_BUS2000113 Process Purchase Contracts
  253. CRMD_BUS2000114 Maintain Sales Contracts
  254. CRMD_BUS2000115 Maintain Sales Transactions
  255. CRMD_BUS2000116 Edit Service Processes
  256. CRMD_BUS2000117 Process Service Confirmations
  257. CRMD_BUS2000120 Process Complaints
  258. CRMD_BUS2000121 Maintain Sales Contracts
  259. CRMD_BUS2000126 Maintain Activities
  260. CRMD_BUS2000210 Maintain Product Service Letter
  261. CRMD_BUS2000220 Maintain Partner Design Project
  262. CRMD_BUS2000230 Maintain License Sales Contracts
  263. CRMD_BUS2000231 Edit License Acquisition Contracts
  264. CRMD_BUS2000232 Edit License Usage Confirmation
  265. CRMD_CALL_LIST Generation of Call Lists
  266. CRMD_CC Currency Change
  267. CRMD_CCKPT_VIEWCUST customizing for role default views
  268. CRMD_CD Display of Document Changes
  269. CRMD_CODEX CRM Codex : Evaluation
  270. CRMD_CSDR_PROJ_FAST Fast entry screen for Project
  271. CRMD_DOWNLOAD_OM CRM Mobile Client Download (Online)
  272. CRMD_DOWNLOAD_SB Download Sales Bundling Data to CDB
  273. CRMD_EMAIL Maintain Mail Form
  274. CRMD_EMAIL_LIST Display Marketing Bus. Activity List
  275. CRMD_EMAIL_TEMPL Maintain Mail Template
  276. CRMD_EMAIL_TEMPL1 Maintain Mail Form
  277. CRMD_EVENT_CHECK EH:Callback for Trans.Type/Item Cat.
  278. CRMD_EVENT_TRACE Evaluate Transaction Event Trace
  279. CRMD_IIA_FAQ Maintain Frequently Asked Questions
  280. CRMD_IIA_REPORT Generate Statistics Reports
  281. CRMD_IM_MAIL_DELETE Delete Marketing Bus. Activity List
  282. CRMD_INDEX_OM Index structure search OM
  283. CRMD_IPM_AVAILABLE Analyze Rights Availability
  284. CRMD_IPM_EVENT Date/Event Management
  285. CRMD_IPM_HIER Maintain Hierarchical Attributes
  286. CRMD_IPM_HIER_VIEW Maintain Hier.Attributes Views
  287. CRMD_IPM_RD_PCUI_GEN IPM: Generate People Centric UI
  288. CRMD_ISA_AUC_ATT Web Auction Attributes Setup
  289. CRMD_ISA_EAUCTION Manage Web Auctions
  290. CRMD_LEAD_FREE_SEL Lead Monitor: Free Selection
  291. CRMD_LEAD_MONITOR Lead Monitor - Organizational View
  292. CRMD_LEAS_ME_ACCRUAL Month-End Accruals
  293. CRMD_MINIPROCESS Process a Transaction from MiniApp
  294. CRMD_MKTDS Data Sources for Segment Builder
  295. CRMD_MKTDS_WIZARD Data Source Wizard
  296. CRMD_MKTLIST External List Management
  297. CRMD_MKTLIST_MAP CRM Marketing : ELM Mapping Tool
  298. CRMD_MKTPL_AL00 CRM: Allocation Application
  299. CRMD_MKTPL_AL02 CRM: Allocation Rules
  300. CRMD_MKTPL_AL03 CRM: Allocation Priorities
  301. CRMD_MKTPL_AL04 CRM: Status of actual quantities
  302. CRMD_MKTSEG Segment Builder
  303. CRMD_MKTSEG_MGR Edit Master Groups/Samples
  304. CRMD_MKT_EXP CRM Marketing: Export Target Group
  305. CRMD_MKT_PROC Create Business Transactions
  306. CRMD_MKT_TOOLS Marketing Tools
  307. CRMD_MKT_TRANS CRM Marketing: Transport to Channels
  308. CRMD_OPPORT_FAST My opportunities - fast change
  309. CRMD_ORDER Transaction Processing
  310. CRMD_ORDER_BP Business Partner Cockpit
  311. CRMD_ORDER_LEAS_WOFF Write-Offs Mass Update Leasing
  312. CRMD_ORDER_OBJLINK CRM Order via BUS Type and Number
  313. CRMD_ORDER_PA Dialog Transaction CRMD_ORDER
  314. CRMD_PROF_BP Business Partner Attributes
  315. CRMD_PROF_CHAR Attribute Maintenance
  316. CRMD_PROF_TEMPL Maintain Attribute Sets
  317. CRMD_ROUTING_PROFILE Maintain Profiles and Attributes
  318. CRMD_SDB_PRMN Maintain Info. Security Profile
  319. CRMD_SDB_PROF Assign Profile to User
  320. CRMD_SERV_CYCLE Define Service Cycles
  321. CRMD_SERV_FORECAST Service Plan Forecasting
  322. CRMD_SERV_SLA Availability and Response Times
  323. CRMD_SRWWW Internet Transaction Service Request
  324. CRMD_TG_IMPORT Import External Target Groups
  325. CRMD_TM_CLDIST Call List Maintenance
  326. CRMD_TM_CLMS Call List Management
  327. CRMD_TRACE_EVAL Evaluation of API Trace
  328. CRMD_TRACE_SET Activate/Deactivate API Trace
  329. CRMD_TRACE_WATCHP Setting/Deletion of Watchpoint
  330. CRMD_TRANSLATE Translate Mail Form
  331. CRMD_TRANS_OM Translate Short Text for Org Units
  332. CRMD_WEBREQ_CUST_OVW Customizing Evaluation: Web Requests
  333. CRMD_WEBREQ_GEN_EXIT Generate start_exit Page
  334. CRMD_WEBREQ_MONITOR Monitor for Web Requests
  335. CRMD_WEBREQ_SIG_SHOW Display Digital Signature
  336. CRMINIT First steps in middleware servers
  337. CRMMDCS MAINT. DECISION TREE
  338. CRMMDTREE The Overall Maintenance
  339. CRMMONITOR Monitoring Middleware System
  340. CRMMTREE SCRPT TREE MAINTENCE
  341. CRMMTREET SCRPT TREE MAINTENCE
  342. CRMM_BPCURR Currency Changeover Business Partner
  343. CRMM_BPD Business Partner Diagnosis
  344. CRMM_BUPA_MAP Business partner data exchange
  345. CRMM_BUPA_SEND Business Partner: Sending Directly
  346. CRMM_CIC_APDISPLAY Display IC WinClient Profile
  347. CRMM_CSDR_PROD_MAIN Des.Reg. product attributes maintain
  348. CRMM_HR_QUALI_DEF Create CRM relevant HR qualis remote
  349. CRMM_HR_QUALI_GET Create attribute f. HR qualification
  350. CRMM_IC_MCM_CCADM Maintain System Settings
  351. CRMM_IC_MCM_CCLNK Assign Profiles
  352. CRMM_ISA_IUSER Internet User Management
  353. CRMM_ISA_UA Internet Sales - User Administration
  354. CRMM_MARKET_ATTRSET Maintain Marketing Set Type
  355. CRMM_MKT_SAMPLE Samples for Segment Builder
  356. CRMM_PPR Maintain Partner/Product Range
  357. CRMM_PPR_CHNG_STATUS Change Partner/Product Range Status
  358. CRMM_PPR_GUID_INFO Program CRM_PRP_GUID_INFO
  359. CRMM_PPR_GUID_PPR Display all GUIDs for a PPR
  360. CRMM_PPR_LISTFORBUPA Program CRM_PRP_LIST_PPRS_FOR_BUPA
  361. CRMM_PPR_LISTFORPROD Program CRM_PRP_LIST_BUPAS_FOR_PROD
  362. CRMM_PPR_RULES Execute Partner/Product Range Rules
  363. CRMM_PPR_SETTYPES Maintain PPR Set Types
  364. CRMM_PPR_STATUS_TEST Change PPR Status for internal use
  365. CRMM_PPR_TOPN Maintain Top n Products
  366. CRMM_PRPROD Assign Pricing Reference Materials
  367. CRMM_ROUTING start business routing
  368. CRMM_ROUTING_COMPARE Business Routing: Compare Scenario
  369. CRMM_ROUT_AGENT Maintain agents for business routing
  370. CRMM_ROUT_GRP Start routing group of b. routing
  371. CRMM_ROUT_GRP_BP Group Members for Routing Groups
  372. CRMM_ROUT_PROF Maintain profile
  373. CRMM_ROUT_PROF_BP Assign Routing Grp Member to Profile
  374. CRMM_ROUT_PROF_CHAR Maintain Attributes
  375. CRMM_ROUT_PROF_TEMP Maintain Profile Template
  376. CRMM_SEARCH Knowledge Search
  377. CRMM_TERRMAN Territory Management
  378. Interactive scripting editor
  379. CRMORDERARC Residence Times Transaction Types
  380. CRMSE62 Activate Exchanged Short Texts
  381. CRMST62 Create Industry Short Texts
  382. CRMS_IC_ACTION_DF IC WebClient Data Flow Maintenance
  383. CRMS_IC_CHECK Check System Settings and Status
  384. CRMS_IC_CROSS_SYS Transaction Launcher Logical Systems
  385. CRMS_IC_SYSTEM_PROPS IC WebClient System Properties
  386. CRMV_CANCPROCEDURE Maintain cancellation procedures
  387. CRMV_CANCRULES Maintain cancellation rules
  388. CRMV_CHECK_EVENTS Check Cust. Tab. for Event Handler
  389. CRMV_CHECK_SSC Check Screen Control Data
  390. CRMV_CODEX CRM Codex: Maint. of Check Tables
  391. CRMV_EVENT Customizing Event Handler
  392. CRMV_GENIL Customizing Object Model Generic IL
  393. CRMV_IPM_EVENTS Define Events
  394. CRMV_IPM_HIER_ATTR Customizing: Hierarchical Attributes
  395. CRMV_IPM_HIER_VIEW Hierarchical Attributes Views
  396. CRMV_PARTY Maintain cancelling party
  397. CRMV_SSC Mntce: Scrn Cntrl Data - CRM Trans.
  398. CRMXIF_C1 Assignment Site ID Interface Type
  399. CRM_AC Check Appointment Rule for Data Exch
  400. CRM_ACE_ADM CRM ACE Administrator Console
  401. CRM_ACE_ADM_OLD Old CRM ACE Activation Tool GUI.
  402. CRM_ACE_DEV CRM ACE Developer Tools
  403. CRM_ACT_CUST_FIELDS Add customer fields to Activity Jrnl
  404. CRM_ACT_IBU_INCL Maintain IBU specific fields
  405. CRM_ACT_JR_TMPT Create/Change Activity Jrnl Template
  406. CRM_ACT_JR_TMPT_TYPE Create/Change Activity JRNL TempType
  407. CRM_ACT_STD_JRNL Create Standard Activity Journal
