[二代] MM01创建物料主数据屏幕增强
Twilight发表于 2015-06-12 13:14chching5050 最后回复于 2022-05-16 16:34 [复制链接] 41062 46
业务场景:MM01/MM02/MM03操作物料主数据时,在基本数据1视图中新增两个字段:旧物料号、基本单位。
1、创建增强2个字段所需的子屏幕
OMT3C(spro->Logistics-General -> Material Master -> Configuring the material master and execute ‘Create Program for Customized subscreen)
2、新建函数组,最好命名ZMGD1,表示这是copy标准程序MGD1用来增强的,这里是测试案例命名无所谓了。
3、SE80打开函数组YMM_FG,画2组元素zmara_old-bismt,zmara_old-meins,参考数据字典打勾
4、0001屏幕程序流
  1. PROCESS BEFORE OUTPUT.
  2. *                      Verarbeitung vor der Ausgabe
  3.   MODULE disable_fields.
  4.   MODULE get_data.
  5. PROCESS AFTER INPUT.
  6. *                      Verarbeitung nach der Eingabe
  7.   MODULE assign_data.
  1. *----------------------------------------------------------------------*
  2. ***INCLUDE LYMM_FGO01.
  3. *----------------------------------------------------------------------*
  5. *&      Module  DISABLE_FIELDS  OUTPUT
  7. *       text
  9. MODULE disable_fields OUTPUT.
  10.   IF sy-tcode = 'MM03'.
  11.     LOOP AT SCREEN.
  12.       screen-input = '0'.
  13.       MODIFY SCREEN .
  14.     ENDLOOP.
  15.   ENDIF.
  16. ENDMODULE.                 " DISABLE_FIELDS  OUTPUT
  17. *&---------------------------------------------------------------------*
  18. *&      Module  GET_DATA  OUTPUT
  19. *&---------------------------------------------------------------------*
  20. *       text
  21. *----------------------------------------------------------------------*
  22. MODULE get_data OUTPUT.
  23.   IF sy-tcode = 'MM03' OR sy-tcode = 'MM02'.
  24.     GET PARAMETER ID w_mat FIELD w_matnr.
  25.     SELECT SINGLE bismt meins
  26.       INTO (zmara_old-bismt,zmara_old-meins)
  27.       FROM zmara_old
  28.       WHERE matnr = w_matnr.
  29.   ENDIF.
  30. ENDMODULE.                 " GET_DATA  OUTPUT
  2. ***INCLUDE LYMM_FGI01.
  5. *&      Module  ASSIGN_DATA  INPUT
  7. *       text
  9. MODULE assign_data INPUT.
  10.   EXPORT zmara_old TO MEMORY ID 'zmara_old'.
  11. ENDMODULE.                 " ASSIGN_DATA  INPUT
LYMM_FGTOP中定义全局变量
  1. FUNCTION-POOL ymm_fg
  2.                    MESSAGE-ID m3.
  3. INCLUDE mmmgtrbb.
  4. INCLUDE mmmgbbau.
  5. * Retail-Spezifische Deklarationen
  6. INCLUDE mmmwtrbb.
  7. INCLUDE mmmwbbau.
  8. *---------------------------------
  9. INCLUDE wstr_definition. "Holds BADI global definition
  10. DATA:w_matnr TYPE mara-matnr.
  11. DATA:w_mat TYPE tpara-paramid.
  12. TABLES:zmara_old.
5、后台将自建的屏幕维护到标准MM01屏幕中
OMT3B(spro -> Logistics-General -> Material Master -> Configuring the material master and execute  ‘Define Structure of Data Screens for Each Screen Sequence’)
选中右侧一条数据,双击左侧data screen
选中右侧Basic Data 1数据,双击左侧Subscreens
选择21->07->08,将刚才新建的函数池SAPLYMM_FG维护到program中,保存。为什么选择21->07->08?
6、找到mm01保存的增强出口se37:EXIT_SAPLMGMU_001
二代增强查找方法:浅谈随着sap的发展而演化出的几代增强
双击INCLUDE ZXMG0U02.新建include
  1. TABLES:zmara_old.
  2. IF sy-ucomm = 'BU'.
  3.   IMPORT zmara_old FROM MEMORY ID 'ZMARA_OLD'.
  4.   MOVE cmara-matnr TO zmara_old-matnr.
  5.   MODIFY zmara_old FROM zmara_old.
  6. ENDIF.
7、MM01测试效果
songxin2000
学习了,谢谢分享
感謝無私分享,學習了!!
fayne
进来看看!!!
学习了,谢谢分享
Jesse
学习一下,,,,
学习学习,楼主棒棒哒
sunshch
楼主你的QQ方便透漏吗?有不明白的地方咨询一下
上班不能上qq的,以后我来建的个吧
jianpano
好贴
学习学习,楼主棒棒哒
jianpano
想问下楼主选21的原因,可以选别的吗
为什么  为什么 学习中。。
tougegelol
支持楼主,支持SAP顾问圈,以后经常来!
xacwc
真是难得给力的好资源啊,SAP顾问圈真是给力。
kinglvcha
谢谢分享。。。不够完善,补充参考:http://blog.csdn.net/heng0757/article/details/8067645
酸酸甜甜的瓜
支持sap顾问圈,顶顶顶
aa775128101
值得学习,很不错
xiaoyuer
學習下哈哈,day day up
冬天不太冷
新手,学习了
Anda
跟着做一下,可以,挺久不弄屏幕,画个屏幕还花了点时间
123下一页
