在Module Pool类型程序中定义range范围
Twilight发表于 2014-10-11 09:16Twilight 最后回复于 2014-10-11 09:16 [复制链接] 4148 0
range table有四个字段,分别是Sign  Option  Low  High,下面将详细讲解在Module Pool类型程序中定义一个range
1、se38 创建一个Module pool (M type)程序,保存
2、se51 为这个程序创建一个9000屏幕
3、点击layout,在屏幕上画one text field, two input/output field and background box
输入框分别命名MLOW和MHIGH
4、se11 为这两个输入框定义一个search help
5、将search help填写到相应的屏幕属性上(mlow和mhigh都填写)
6、放开逻辑流中的module User_command_9000
7、se93 为程序定义一个T-code
8、程序代码:
  1. TYPE-POOLS:SLIS.
  2. TABLES : MARA .
  3. DATA :MLOW(18),MHIGH(18).
  4. DATA :MLOW1(18),MHIGH1(18).
  5. DATA: BEGIN OF T_MARA OCCURS 1,
  6.         MATNR TYPE MARA-MATNR,
  7.         ERSDA TYPE MARA-ERSDA,
  8.         ERNAM TYPE MARA-ERNAM,
  9.         PSTAT TYPE MARA-PSTAT,
  10.         MBRSH TYPE MARA-MBRSH,
  11.       END OF T_MARA.
  12. DATA : BEGIN OF RANGE OCCURS 0 ,
  13.        SIGN(1),
  14.        OPTION(2),
  15.        LOW(18),
  16.        HIGH(18),
  17.        END OF RANGE .
  18. DATA : T_FCAT TYPE TABLE OF SLIS_FIELDCAT_ALV ,
  19.        W_FCAT TYPE SLIS_FIELDCAT_ALV ,
  20.        W_LAYO TYPE SLIS_LAYOUT_ALV .
  21. *&---------------------------------------------------------------------*
  22. *&      Module  USER_COMMAND_9000  INPUT
  23. *&---------------------------------------------------------------------*
  24. *       text
  25. *----------------------------------------------------------------------*
  26. MODULE USER_COMMAND_9000 INPUT.
  27.   CASE SY-UCOMM.
  28.     WHEN ''."FC-CODE OF ENTER BUTTON
  29.       CALL FUNCTION 'CONVERSION_EXIT_MATN1_INPUT' "CONVERSION ROUTINE FOR MLOW
  30.         EXPORTING
  31.           INPUT              = MLOW
  32.        IMPORTING
  33.          OUTPUT             = MLOW1
  34.        EXCEPTIONS
  35.          LENGTH_ERROR       = 1
  36.          OTHERS             = 2
  37.                 .
  38.       IF SY-SUBRC <> 0.
  39.         MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
  40.                 WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
  41.       ENDIF.
  42.       CALL FUNCTION 'CONVERSION_EXIT_MATN1_INPUT'"CONVERSION ROUTINE FOR MHIGH
  43.         EXPORTING
  44.           INPUT              = MHIGH
  45.        IMPORTING
  46.          OUTPUT             = MHIGH1
  47.        EXCEPTIONS
  48.          LENGTH_ERROR       = 1
  49.          OTHERS             = 2
  50.                 .
  51.       IF SY-SUBRC <> 0.
  52.         MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
  53.                 WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
  54.       ENDIF.
  55. ******************************************************************
  56. * LOGICALLY BUILD A INTERNAL TABLE (RANGE)
  57. ******************************************************************
  58.       RANGE-SIGN = 'I'. " I OR E
  59.       RANGE-OPTION = 'BT'.
  60.       RANGE-LOW = MLOW1 .
  61.       RANGE-HIGH = MHIGH1 .
  62.       APPEND RANGE ."APPEND DATA IN INTERNAL TABLE
  63. ******************************************************************
  64.       PERFORM FETCH_DATA .
  65.       PERFORM DISPLAY_DATA .
  66.   ENDCASE.
  67. ENDMODULE.                 " USER_COMMAND_9000  INPUT
  68. *&---------------------------------------------------------------------*
  69. *&      Form  FETCH_DATA
  70. *&---------------------------------------------------------------------*
  71. *       text
  72. *----------------------------------------------------------------------*
  73. *  -->  p1        text
  74. *  <--  p2        text
  75. *----------------------------------------------------------------------*
  76. FORM FETCH_DATA .
  77.           SELECT  MATNR
  78.                   ERNAM
  79.                   ERSDA
  80.                   PSTAT
  81.                   MBRSH
  82.                   FROM MARA
  83.                   INTO CORRESPONDING FIELDS OF TABLE T_MARA
  84.                   WHERE MATNR IN RANGE .
  85. ENDFORM.                    " FETCH_DATA
  86. *&---------------------------------------------------------------------*
  87. *&      Form  DISPLAY_DATA
  88. *&---------------------------------------------------------------------*
  89. *       text
  90. *----------------------------------------------------------------------*
  91. *  -->  p1        text
  92. *  <--  p2        text
  93. *----------------------------------------------------------------------*
  94. FORM DISPLAY_DATA .
  95.   LEAVE TO LIST-PROCESSING .
  96.   W_FCAT-TABNAME = 'MARA'.
  97.   W_FCAT-FIELDNAME = 'MATNR'.
  98.   W_FCAT-SELTEXT_M = 'Material No'.
  99.   APPEND w_fcat to t_Fcat .
  100.     W_FCAT-TABNAME = 'MARA'.
  101.   W_FCAT-FIELDNAME = 'ERSDA'.
  102.   W_FCAT-SELTEXT_M = 'Created On'.
  103.   APPEND w_fcat to t_Fcat .
  104.     W_FCAT-TABNAME = 'MARA'.
  105.   W_FCAT-FIELDNAME = 'ERNAM'.
  106.   W_FCAT-SELTEXT_M = 'Name of Person'.
  107.   APPEND w_fcat to t_Fcat .
  108.     W_FCAT-TABNAME = 'MARA'.
  109.   W_FCAT-FIELDNAME = 'PSTAT'.
  110.   W_FCAT-SELTEXT_M = 'Maintenance status'.
  111.   APPEND w_fcat to t_Fcat .
  112.     W_FCAT-TABNAME = 'MARA'.
  113.   W_FCAT-FIELDNAME = 'MBRSH'.
  114.   W_FCAT-SELTEXT_M = 'Industry sector'.
  115.   APPEND w_fcat to T_FCAT.
  116.   W_LAYO-ZEBRA = 'X'.
  117.   W_LAYO-COLWIDTH_OPTIMIZE = 'X'.
  118.   CALL FUNCTION 'REUSE_ALV_GRID_DISPLAY'
  119.    EXPORTING
  120. *   I_INTERFACE_CHECK                 = ' '
  121. *   I_BYPASSING_BUFFER                = ' '
  122. *   I_BUFFER_ACTIVE                   = ' '
  123. *   I_CALLBACK_PROGRAM                = ' '
  124. *   I_CALLBACK_PF_STATUS_SET          = ' '
  125. *   I_CALLBACK_USER_COMMAND           = ' '
  126. *   I_CALLBACK_TOP_OF_PAGE            = ' '
  127. *   I_CALLBACK_HTML_TOP_OF_PAGE       = ' '
  128. *   I_CALLBACK_HTML_END_OF_LIST       = ' '
  129. *     I_STRUCTURE_NAME             = 'MARA'
  130. *   I_BACKGROUND_ID                   = ' '
  131.      I_GRID_TITLE                      ='MATERIAL REPORT'
  132. *   I_GRID_SETTINGS                   =
  133.    IS_LAYOUT                         = W_LAYO
  134.    IT_FIELDCAT                       = T_FCAT
  135. *   IT_EXCLUDING                      =
  136. *   IT_SPECIAL_GROUPS                 =
  137. *   IT_SORT                           =
  138. *   IT_FILTER                         =
  139. *   IS_SEL_HIDE                       =
  140. *   I_DEFAULT                         = 'X'
  141. *   I_SAVE                            = ' '
  142. *   IS_VARIANT                        =
  143. *   IT_EVENTS                         =
  144. *   IT_EVENT_EXIT                     =
  145. *   IS_PRINT                          =
  146. *   IS_REPREP_ID                      =
  147. *   I_SCREEN_START_COLUMN             = 0
  148. *   I_SCREEN_START_LINE               = 0
  149. *   I_SCREEN_END_COLUMN               = 0
  150. *   I_SCREEN_END_LINE                 = 0
  151. *   I_HTML_HEIGHT_TOP                 = 0
  152. *   I_HTML_HEIGHT_END                 = 0
  153. *   IT_ALV_GRAPHICS                   =
  154. *   IT_HYPERLINK                      =
  155. *   IT_ADD_FIELDCAT                   =
  156. *   IT_EXCEPT_QINFO                   =
  157. *   IR_SALV_FULLSCREEN_ADAPTER        =
  158. * IMPORTING
  159. *   E_EXIT_CAUSED_BY_CALLER           =
  160. *   ES_EXIT_CAUSED_BY_USER            =
  161.     TABLES
  162.       T_OUTTAB                          = T_MARA[]
  163. * EXCEPTIONS
  164. *   PROGRAM_ERROR                     = 1
  165. *   OTHERS                            = 2
  166.             .
  167.   IF SY-SUBRC <> 0.
  168. * MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
  169. *         WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
  170.   ENDIF.
  171. ENDFORM.                    " DISPLAY_DATA
9、执行程序,查看效果
输入条件enter回车
