[BDC] BDC录屏实现MIRO采购订单发票过账
Twilight发表于 2019-08-07 10:59Twilight 最后回复于 2019-08-07 10:59 [复制链接] 10077 0
采购订单发票过账SAP提供了标准BAPI:BAPI_INCOMINGINVOICE_POST,请参考MIRO过账采购订单发票BAPI_INCOMINGINVOICE_POST
为什么还使用BDC呢?为了在过账时填写参考、抬头文本等备注信息,录屏时注意公司代码,界面使用了SAP内存,所以录屏不一定会有公司代码弹框。
  1. FUNCTION zpufm023.
  3. *"*"本地接口
  4. *"  IMPORTING
  5. *"     VALUE(I_BELNR) TYPE  RE_BELNR
  6. *"     VALUE(I_GJAHR) TYPE  GJAHR
  7. *"     VALUE(I_XBLNR) TYPE  XBLNR1 OPTIONAL
  8. *"     VALUE(I_BKTXT) TYPE  BKTXT OPTIONAL
  9. *"  EXPORTING
  10. *"     VALUE(E_MESSAGE) TYPE  ZOTS001
  11. *"----------------------------------------------------------------------
  12.   DATA:lt_messtab TYPE TABLE OF bdcmsgcoll.
  13.   DATA:lt_return TYPE TABLE OF bapiret2 WITH HEADER LINE.
  14.   DATA:ls_rbkp TYPE rbkp.
  15.   PERFORM frm_re_belnr_input CHANGING i_belnr.
  16.   SELECT SINGLE * INTO ls_rbkp FROM rbkp WHERE belnr = i_belnr AND gjahr = i_gjahr.
  17.   IF sy-subrc = 0.
  18.     IF ls_rbkp-rbstat = '5'.  "5  已过账
  19.       e_message-type    = 'S'.
  20.       e_message-message = 'PO预制发票已经过账!'.
  21.       EXIT.
  22.     ENDIF.
  23.   ELSE.
  24.     e_message-type    = 'E'.
  25.     e_message-message = 'PO预制发票不存在!'.
  26.     EXIT.
  27.   ENDIF.
  28.   SET PARAMETER ID 'BUK' FIELD ls_rbkp-bukrs.
  29. *MIRO 菜单-显示
  30.   PERFORM bdc_dynpro      USING 'SAPLMR1M' '6000'.
  31.   PERFORM bdc_field       USING 'BDC_OKCODE'
  32.                                 '/EMR3M'.
  33. *输入PO发票号码
  34.   PERFORM bdc_dynpro      USING 'SAPLMR1M' '6150'.
  35.   PERFORM bdc_field       USING 'BDC_OKCODE'
  36.                                 '/00'.
  37.   PERFORM bdc_field       USING 'RBKP-BELNR'
  38.                                 i_belnr.
  39.   PERFORM bdc_field       USING 'RBKP-GJAHR'
  40.                                 i_gjahr.
  41. *MIRO 菜单-修改
  42.   PERFORM bdc_dynpro      USING 'SAPLMR1M' '6000'.
  43.   PERFORM bdc_field       USING 'BDC_OKCODE'
  44.                                 '/EPPCH'.
  45. *参考单号
  46.   PERFORM bdc_dynpro      USING 'SAPLMR1M' '6000'.
  47.   PERFORM bdc_field       USING 'BDC_OKCODE'
  48.                                 '=HEADER_FI'.
  49.   IF i_xblnr IS NOT INITIAL.
  50.     PERFORM bdc_field       USING 'INVFO-XBLNR'
  51.                                   i_xblnr.
  52.   ENDIF.
  53. *抬头文本
  54.   PERFORM bdc_dynpro      USING 'SAPLMR1M' '6000'.
  55.   PERFORM bdc_field       USING 'BDC_OKCODE'
  56.                                 '=BU'.
  57.   IF i_bktxt IS NOT INITIAL.
  58.     PERFORM bdc_field       USING 'INVFO-BKTXT'
  59.                                   i_bktxt.
  60.   ENDIF.
  61.   PERFORM bdc_transaction TABLES lt_messtab
  62.                           USING  'MIRO'
  63.                                   'X' "CALL TRANSACTION 方式
  64.                                   'N'
  65.                                   'S'.
  66.   IF sy-subrc NE 0.
  67.     e_message-type    = 'E'.
  68.     CALL FUNCTION 'CONVERT_BDCMSGCOLL_TO_BAPIRET2'
  69.       TABLES
  70.         imt_bdcmsgcoll = lt_messtab
  71.         ext_return     = lt_return.
  72.     LOOP AT lt_return  WHERE type CA 'AEX'.
  73.       IF e_message-message IS INITIAL.
  74.         e_message-message   = lt_return-message.
  75.       ELSE.
  76.         CONCATENATE e_message-message lt_return-message INTO e_message-message SEPARATED BY '/'.
  77.       ENDIF.
  78.     ENDLOOP.
  79.   ELSE.
  80.     e_message-type    = 'S'.
  81.     e_message-message = 'PO预制发票过账成功!'.
  82.   ENDIF.
  83. ENDFUNCTION.
  84. INCLUDE bdcrecxy .
分析的好有道理,但是最后测试发现dump:CNTL_ERROR异常,SAP给出解释:
  1. miro is an enjoy transaction, so it will fail in background, though it runs in foreground. so try to use BAPI inplace of it.
替代方案:
  1. FUNCTION zpufm020.
  3. *"*"本地接口:
  4. *"  IMPORTING
  9. *"  EXPORTING
  12.   DATA:lt_return TYPE TABLE OF bapiret2 WITH HEADER LINE.
  13.   DATA:ls_headerdata_change  TYPE bapi_incinv_chng_header.
  14.   DATA:ls_headerdata_changex TYPE bapi_incinv_chng_headerx.
  15.   DATA:ls_rbkp  TYPE rbkp.
  16.   PERFORM frm_re_belnr_input CHANGING i_belnr.
  17.   SELECT SINGLE * INTO ls_rbkp FROM rbkp WHERE belnr = i_belnr AND gjahr = i_gjahr.
  18.   IF sy-subrc = 0.
  19.     IF ls_rbkp-rbstat = '5'.  "5  已过账
  20.       e_message-type    = 'S'.
  21.       e_message-message = 'PO预制发票已经过账!'.
  22.       EXIT.
  23.     ENDIF.
  24.   ELSE.
  25.     e_message-type    = 'E'.
  26.     e_message-message = 'PO预制发票不存在!'.
  27.     EXIT.
  28.   ENDIF.
  29. *-->BAPI_INCOMINGINVOICE_CHANGE
  30.   ls_headerdata_change-ref_doc_no = '00100653'.
  31.   ls_headerdata_change-header_txt = '确认发票自动生成的过账凭证'.
  32.   ls_headerdata_changex-ref_doc_no = 'X'.
  33.   ls_headerdata_changex-header_txt = 'X'.
  34.   CALL FUNCTION 'BAPI_INCOMINGINVOICE_CHANGE'
  35.     EXPORTING
  36.       invoicedocnumber   = i_belnr
  37.       fiscalyear         = i_gjahr
  38.       headerdata_change  = ls_headerdata_change
  39.       headerdata_changex = ls_headerdata_changex
  40.     TABLES
  41.       return             = lt_return.
  42.   LOOP AT lt_return WHERE type CA 'AEX'.
  43.     IF e_message-message IS INITIAL.
  44.       e_message-message   = lt_return-message.
  45.     ELSE.
  46.       CONCATENATE e_message-message lt_return-message INTO e_message-message SEPARATED BY '/'.
  47.     ENDIF.
  48.   ENDLOOP.
  49.   IF sy-subrc = 0.
  50.     CALL FUNCTION 'BAPI_TRANSACTION_ROLLBACK'.
  51.     e_message-type   = 'E'.
  52.     EXIT.
  53.   ELSE.
  54.     CALL FUNCTION 'BAPI_TRANSACTION_COMMIT'
  55.       EXPORTING
  56.         wait = 'X'.
  57. *-->BAPI_INCOMINGINVOICE_POST
  58.     CLEAR:lt_return[].
  59.     CALL FUNCTION 'BAPI_INCOMINGINVOICE_POST'
  60.       EXPORTING
  61.         invoicedocnumber = i_belnr
  62.         fiscalyear       = i_gjahr
  63.       TABLES
  64.         return           = lt_return.
  65.     LOOP AT lt_return WHERE type CA 'AEX'.
  66.       IF e_message-message IS INITIAL.
  67.         e_message-message   = lt_return-message.
  68.       ELSE.
  69.         CONCATENATE e_message-message lt_return-message INTO e_message-message SEPARATED BY '/'.
  70.       ENDIF.
  71.     ENDLOOP.
  72.     IF sy-subrc = 0.
  73.       CALL FUNCTION 'BAPI_TRANSACTION_ROLLBACK'.
  74.       e_message-type   = 'E'.
  75.       EXIT.
  76.     ELSE.
  77.       CALL FUNCTION 'BAPI_TRANSACTION_COMMIT'
  78.         EXPORTING
  79.           wait = 'X'.
  82.     ENDIF.
  83.   ENDIF.
  84. ENDFUNCTION.
  85. FORM frm_re_belnr_input CHANGING pc_belnr TYPE re_belnr.
  86.   CALL FUNCTION 'CONVERSION_EXIT_ALPHA_INPUT'
  87.     EXPORTING
  88.       input  = pc_belnr
  89.     IMPORTING
  90.       output = pc_belnr.
  91. ENDFORM.
